Strange Monitor, or maybe Graphics card issue.
Nothgard
I have a pretty strange issue here.
I took about my computer to clean it, and I took all necessary precautions, anti-static wrist strip, and bags, so on.
When all put about together my two displays, both Acer G205hv's, just said no signal. I've tested an endless amount of things, They are both working on DVI.
First I thought it was my video cards, so I tried the basic things, test connections, making sure it was all seated correctly, making sure it had power. That seemed all well. I also checked ram, to see if it was stopping it somehow, all fine there as well. I could always here windows log in whenever I turned my computer on.
I have two video cards, and I tested them SLI'd and non-SLI'd, didn't seem to make a difference either way.
So I moved on, I hooked up my TV using the mini-hdmi port, and that worked. so once in the OS I started messing with Nvidia settings, the monitors wouldn't even be detected by Windows.I tried reinstalling the drivers, twice, one a normal install, the second I did a complete removal first, that didn't work either. I checked Bios, messed with some setting there, and even end up doing a BIOs reset, still nothing. I have checked all my PCI ports, they all functions, So I started to look at my monitors themselves. I tested one on another computer, and it worked on that computer, and I tested a third, very different, monitor on my computer, and it worked Windows detected it and everything. So I did a reset on my monitors, and that didn't help either.
So my DVI monitors don't work on my computer, but my mini-hdmi does. My monitors work on other computers, and other monitors work on my computer.
PCI slots work, graphic cards work, everything else seems to function fine. I don't know what else to do here.
Computer specs, if it helps any.
Motherboard:Asus Sabertooth Z77 motherboard
CPU:Intel Core i5 3570k
RAM:16GBs Patriot RAM, DRR3
GPU:Nvidia EVGA 550 TI x2
Monitors: Acer G205HV
