Strange message after overclocking 7850, PLEASE HELP!
Borky1211
Hey guys, I have a quick question and hopefully one of you has a solution. Today I overclocked my diamond 7850 for the first time. I followed this guide exactly...I think
http://www.reddit.com/r/gamingpc/comments/twcrh/7850_overclocking_guide/
I got everything to work and the computer works but when I first start up
windows and get to the start screen, I am welcomed with this message..." windows cannot find C:\Program Files(x86)\AMD AVT\bin\kdbsync. exe' Make sure you typed the name correctly, and try again."
This is a brand new computer I built and this only happened after I DL that asus GPU tweak and did everything that the guide told me to do. How can I get rid or fix that message? Please someone help and tell me I don't have some sort of virus or something.
Its part of the AMD Advanced Video Transcoding technology. Just reinstall drivers or so.
kbsync.exe came with your AMD video driver update. It is designed to run automatically in the background to convert video files during drag-and-drop actions from, say, your computer to a portable video device, all by using the video card(s) themselves.
