BTRY B 529th FA BN
I recently swapped out my Enermax Revo 950 with my Seasonic X 650 Gold and things started acting up.
The symptoms are this:
The machine will power up but the system does not boot. The video card fan runs faster than normal but no screen.
What I do is simply hit the restart button right away and sometimes it will boot like normal.
RebateMonger suggested it was the bios battery. So this morning I went to get one (store was closed, came back) tried to start the machine without the bios battery and I had a few reboots until i got here.... Currently I am booted into my system (doesn't look normal) .. without a bios battery. All my settings have stayed the same (AHCI mode, DRAM voltage, nothing has changed)
Possibilities:
mb is going bad ?
Bios battery? What are the normal specs of a bios battery? 3v Lithium?
EDIT: if it is the MB, I can still salvage the Q9650 and the 8g of DDR2, but a new MB would require at-least 8 SATA ports
Possibilities:
mb is going bad ?
