- Apr 5, 2005
- 20
- 0
- 0
Ok i have a network setup that goes like this: I have 2 pcs, and a netgear hub. I connect the 2 pcs to the hub. I also have a sbc dsl modem, and i also connect the ethernet cable to hub (instead of directly to the ethernet card on teh pc). This way, i get a connection on both computer...its worked for over a year. Recently i got a new computer. I sold my old one and hooked up my new comp to the network setup. It worked...for about 2 days. I unplugged the cables yesterday to switch the places of teh two computers. When i reconnected the cables, i got the ip address conflict problem. Ive done the config /release/renew command, i've tried manually entering in ips (192.168.1.xxx). When i renew the ip it says the ip assigned by the dhpc server conflicts with another ip. I cant automatcally assign ips either b/c they assign the same ips. Whats weird was it was working jsut a couple of days before. I have no idea what to do. Maybe im doing something wrong when i try manually entering it?
Edit: btw, my dsl works fine when i plug it directly into one pc.
