Sorry for the late reply.Try the new USB disk maker its very useful
I only have an 8GB USB disk; is that big enough?
WinDFT detects no hard drive. Odd.I'd download and run Hitachi's WinDFT software to test the hard drive for faults.
I did a fresh install when I replaced the motherboard, so the dump file is gone (if there was one)Also, as you indicate you had a previous BSOD, try downloading and installing the free version of Whocrashed to see if you can learn anything else about it. If Whocrashed can't find a system dump file, go in to the Advanced System Properties and make sure your system is set up to write dump files on crashes in case it happens again.
Nobody?
I'm thinking of replacing the hard drive, because I think that's the issue. The hard drive LED stops blinking completely, but the disk drive still opens, etc.
I was thinking of getting a Crucial M500 120GB SSD and a Seagate Barracuda 1TB. Are there good choices?
Here are some links:
www.amazon.com/dp/B005T3GRNW/
www.amazon.com/dp/B00BQ4F9ZA/
Would it be worth it to spend the extra $20 or so to get a Crucial M550? Is it really that different?
I just replaced the motherboard and was having the freezing issue before that so it can't be the motherboard.Sorry, been busy this weekend. The fact that the drive isn't being detected isn't good. At minimum you have a bad drive, worst case you have a bad motherboard. One thing you can try if you haven't done it is to swap out the SATA cable just to be sure you don't have a bad one.
Do you think I'd be better off getting a 1TB hybrid drive?The M550 is generally a lot faster than the M500 on a SATA3 connection -- the $20 would be money well spent. You might also want to consider going with a 200+GB SSD if you can catch one on sale (TigerDirect has the Seagate Pro 600 series 240GB for $119 shipped -- see the Hot Deals forum for VirtualLarry's post there).
I can afford an SSD, I was just wondering if they're better for the price.I can't answer that question as I've never messed with hybrid drives before. If I am going to go to the trouble of converting a system to an SSD, I want the most performance possible. A hybrid drive isn't going to be anywhere near as fast as an SSD, plus it has twice the possible failure points. However, it could be an option if the budget isn't there for both.
Alright, SSD + HDD it is.Depends. I went from a 120GB SATAII SSD, to a 2TB Seagate 7200RPM desktop hybrid (SSHD) drive, in this box. Partially, because I wanted more space, and partially, because this slimline PC only has two SATA ports, and one is taken up by the DVD-RW. So really, I couldn't go with the preferred SSD+HDD, and then DVD setup.
My experiences with the hybrid drive so far - it's kind of a gimmick. It's good for fast bootups (after about five cold boot cycles), but not much else. Windows Updates go kind of slowly, so do MalwareBytes scans. Slowly compared to a pure SSD. Probably about comparable to a modern 7200RPM HDD.
So I noticed that every time I play BF4 about 5 minutes in the computer freezes. I don't get this with other games, just BF4.
Is there something else that would be causing this? Or does BF4 just put a lot of stress on the hard drive or something? I don't want to spend $120 on an SSD and HDD and move all my files over just to find it isn't the issue.
No, I have not, although I doubt that that would be causing courruption to files on my hard drive.Unfortunately, you've reached an impass here. You won't be able to further troubleshoot without starting to swap stuff out.
Have you tried testing your video card for stability using something like FurMark?
