Strange display trouble
neilganon
16
I got my new Benq e2200hd the other day, and the problem is this: when I have it connected by DVI, after I log in to Windows XP the display freaks out and then shows a static, messed up image. This doesn't happen over VGA, and I tried a different DVI cable and it gave the same problem. It doesn't do it when connected to another computer.
I can start up with a different monitor, hook up the Benq, then switch through the nvidia control panel and it works perfectly. Also, when two monitors are hooked up the freaking-out happens on both. The drivers for the monitor are installed.
So I'm thinking it has something to do with my graphics card (8800 gts 512.) It has two DVI outputs and up until now I've had it connected by VGA using an adapter. Other than that I have no idea what it could be or what to do. Input would be very appreciated!
krnmastersgt
2,873
Or try fresh installing the drivers, if that doesn't work then try swapping the video cards around etc.
If all else fails, then yes, it might require replacing the video card.
