- Dec 4, 2004
- 493
- 0
- 0
So, I'm trying to figure out the reason why my computer has been randomly crashing the past 2-3 weeks. It occurs most often if I'm playing a game, but it also happens during normal web browsing and other simple tasks. In the game is would lock up, sometimes the screen would scramble, then it would go black.
My chipset fan broke 2-3 months ago, I got that replaced, but my motherboard temperature read in the high 50's to low 60's C even after fixing the fan. I originally thought this was the most likely cause of the problem. I don't know if the temperature prob is accurate since the fan is working fine now.
The last 2-3 days the problem seemed to be getting worse. I would lock up in a game or browsing the web more often and it wouldn't even post(It would turn on, but not post) several times. a couple of times the post screen looked garbled and unreadable. The next time I locked up, I reset and could hear the post beep, but I had no video. I have an SLI setup so I decided to take out the 2nd card and see what happened. Well, since then I haven't had any crashes and it seems to be running ok. The motherboard temperature is reading about 40C now as well.
Now, does anybody know if the SLI could have been the cause, or is it just a coincidence? If it is the cause I don't know why it would start doing this after more than 2 years of running ok.
System specs:
WinXP
Athlon 64 3500+
Asus A8N SLI Deluxe Motherboard
2 BFG Geforce 6800 GT video cards
2 GB Corsair RAM
550W Antec PSU
Thanks for any input.
System specs:
WinXP
Athlon 64 3500+
2 GB Corsair RAM
550W Antec PSU
