Hello all of a suden i started haveing problems with my system that I have had toghether for quite sometime now. My guess would be just about a year. Anyways the problem started up yesterday when all of a suden every so often my computer would reset when i was in windows. After the second time it hapend i decided i beter have a look into it. I found that my cpu temp was at 59C. I look at my fan speeds also those are all fine and working just as they had in the past before this problem. So i turn of my system open the case up and have a look around. Didnt find anything out of the ordinary. Since it was late at night i turned my comp off and went to bed.
So now today i turn it on again and after it warms up i find the temp at 53C when my comp is ideling. I also take note of the case temp wich shows 32C. That is the same as it allways has been so no change there. I am runing a amd xp 2200+ A core with retail heatsink and artic silver thermal compound. My cpu before this hapend yesterday used to idel at 47C. What would cause this increase in heat all of a suden without the fans being an issue from what i can see.
Also for notice im runing 2 intake fans(sunnon 40cfm), one side intake fan(sunnon 40cfm), rear case output fan(sunnon 40cfm), pci slot blower card cooling video card, 350 watt sparkle psu, cpu heatsink fan at 5600 rpm. Plain baige enlight mid tower atx case(not sure of module number).
