I have a 95 Nissan Altima with 176k miles. I was driving home from work when halfway home I started loosing power. My cruise control disengaged, my heater fan was turn to max but hardly blowing out any air and the lights were dim compaired to normal and my radio shut off. I never had this problem before. Well I did manage to get home i turned to engine off and then tried to restart it. Dead battery(of course) I'm thinking it might be the alternator but after charging the battery any getting it "tested" at autozone the battery was getting 13.25 volts while the engine was running and they said it appears to be getting enough jucie(however my book say 14v - 15V)
A side note: there sounds like there is a whining noise comming from under the hood. The best way to discribe the noise is: The way an electric drill sounds when trying to drill through something with a nearly dead battery.
Is this the signs of an alternator that is shot(it's the orginal one)
I haven't had any problems since I charged the battery drive to autozone and back home(so far).
