strange boot up problem
jay75
111
sometimes my computer doesn't boot up, i then go push on the power connection in a bit even though its absolutely tight as well as other connection, even the hard disk power and data cables. it then boots up fine. sometimes it hangs after variable lenghts of time. sometimes when i reboot, the bios gets reset. it has also shown signs of corruption. this same problem used to happen to my old mobo, the bios reset and the no boot-up.
the strange thing is than the problem goes away simply by pushing on already tight cables. where does the problem originate from?
