- Jan 26, 2005
- 3,824
- 10
- 81
I recently had a strange problem start occuring. When I turn on my computer, all the fans run at full speed, and stay at full speed. No video appears, although it does boot into windows. If I leave the computer like this for a while, turn it off, and turn it back on, it will boot up fine, with the fans going to regular speed and video showing up after a few seconds. Also, I can turn it on and off multiple times and it will eventually work. It seems almost like it has to "warm up" before being able to turn on properly. My system is:
DFI NF4 SLI-D
Opteron 165 @ 2.6 (have tried it at stock, problem still occurs)
2x 1 GB sticks ram
X1900XTX
2 HDDs
1 Optical
Enermax 420 watt psu
At first I considered the that the psu might not be providing enough power, but I'm not sure about that as I was running the same setup with 7800gts in sli without problems before, and they draw about the same amount of power. This problem started occuring after I bought the X1900XTX, but I can't be sure it's the problem either, because it didn't occur for a while after I bought it.
Also, one more problem - if I try and put the computer in standby mode, the cpu temps shoot up to about 65 C after turning it back on, and the fan sounds strange. Because of this, I can't use standby, which is really annoying. This started happening after I got the 165.
DFI NF4 SLI-D
2x 1 GB sticks ram
X1900XTX
2 HDDs
1 Optical
