Strait-Line 6045704 2-Tool Combo Kit - 6041101 Laser level 120 & 6041501 Stud Finder 150
Price: $9.95. Free ship 25+. Tax in some states.
Technical Details
* 360° rotation for expansive 120 ft. work area
* 4 times brighter laser for best line visibility
* Accuscan technology is specifically calibrated for finding studs behind drywall, paneling & flooring
* Auto marking button keeps surface clean - no pencil needed
* Ideal for hanging cabinets & shelves, leveling trim work, picture arrangements & installing cabinets
Product Description
This great combo kit from Strait-Line includes a Laser Level and a Stud Finder. The 6041101 Laser Level 120 provides you with a 4x brighter laser for best line visibility and is great for brightly lit conditions. It allows 360 degree rotation for an expansive 120 ft. work area. With 3M Command Strips, you can mount the tool to any surface and remove with no damage, allowing you to work hands free. Dual bubble vials are easy to read for accurate horizontal and vertical layouts. The laser level 120 is ideal for hanging cabinets or heavy shelving, leveling trim work, ceilings and flooring or picture arrangements. It runs on (4) AA batteries, which are not included. The 6041501 Stud Finder 150 comes with Accuscan technology which provides you with three surface modes and is specifically calibrated for finding studs behind drywall, paneling and flooring. An auto marking button keeps the surface clean, no pencil is needed. An automatic on/off switch turns the unit on when it comes in contact with any surface. LED and audio alerts clearly identify stud location and an integrated belt clip keeps the tool close at hand. The Stud Finder 150 is ideal for installing bathroom fixtures, shelves, hanging heavy objects and installing window coverings. It runs on (1) 9V battery which is not included. Both tools come with a 5 year warranty from Strait-Line.
