Originally posted by: Fern
Originally posted by: Insane3D
Meh. I bring a system into work every night, and it's in my car all day. The last few days the temperature was as low as 10F, and as "high" as 22F...I bring it right in and fire it up. Thing is, when it's this cold out, the air is super dry, so condensation is a non-issue.
True, but if he brings it inside and lets it sit, the warm air will/may cause condensation to form on the colder PC parts.
Fern
It'll be in Salt Lake City, UT, so probably pretty low humidity.. at least here in Idaho there is hardly any humidity.
Yeah, I live in the Smoky Mountains in NC. Our humity can be fairly low, like 30%, but indoors with peeps breathing (as mentioned above), taking showers, cooking etc the humidity builds up indoors. Even with "dry heat" (fire place and fuel oil furnace) which wrings ever more moisture out of the air, I get condensation build up on the inside of my windows.
Humidity is relative to temperature too. Air at 65 degrees with humidity at 30% holds much more moisture than air at 30 degrees and humidity of 30%.
In your house, if you have a glass/beverage with ice cubes in it, doesn't it get condensation on the o/s?
Perhaps you should let the PC sit for 10-15 minutes once indoors and see if any condensation builds up on the outside just to see what's gonna happen. My other thought is to fire it up right away, it'll warm up and eliminate any chance of condensation. That's what I have done, but am reluctant to suggest it outright for you for fear you may have a prob.
Fern
BTW: I have not found that the cold in and of itself to be a problem. The rig in my sig sits in an unheated room usually. Often the temps are below freezing when I first go to play. Only prob I have ever had is that I must put a blow drier or something on my PSU to get it to start up. Otherwise, these conditions are great for OCing
