Question Storage is better internal sata dvd drive or external usb drive
gamerfan
For long-term storage and preservation drive, is it better to buy an internal SATA DVD drive or an external USB drive?
That really depends on how you define long term.
If we're talking 5-10 years, an external HDD is the easiest solution. If we're talking really long term, like 25-50 years, I'd look into optical storage.
This is a complex subject, and there isn't any one-size-fits-all solution, so what's best depends on your specific needs.
I'm not referring to media but to the DVD reader / writer drive
about the media I like long term storage
storage 25, 50 or more years
The two are closely linked. I suspect that in 50 years, the trickiest part might actually be finding a drive to read the discs. The discs themselves will likely be fine, provided they're stored properly.
As for how long the discs last, I still have CD-Rs from the mid 90s which are perfectly readable. So CDs are good for 25 years at least, provided you use quality media. Writable DVDs haven't been around that long, so nobody knows quite how they stack up long term.
For archiving with optical discs, you want phase change media. Which means either blu-rays (NOT the LTH variety) or DVD-RAM (no, not a typo) but they litterally don't make those anymore. Which is a damn shame, because they're essentially the optical equivalent of a harddrive.
i have a slot load 3.0 pioneer bluray burner that i use for a occasional dvd burn. i love it and most of the time it is put away, when i need to use it take it out and plug it in. (save electricity over a drive always powered on in your pc heh)
It doesn't matter which you use, internal or external, though long term USB should continue to be accessible on more systems going forward. SATA will slowly get phased out from mainstream motherboards, though how long that takes will itself depend on how long it takes the capacity of solid state drives to catch up with that of mechanical hard drives (i.e. it ain't happening any time really soon, though). To cover yourself, you can also get an external SATA to USB enclosure for optical drives.
Optical drives themselves are now in the process of slowly falling out of mainstream, so if you are investing in the format for long term storage you'd want to make sure you invest in both a primary drive and at least a new boxed spare while they are semi-affordable.
The best optical storage you can get for long term storage is a drive that supports M-Disc as the media literally lasts forever and, once written, can be read on any comparable non M-disc optical drive. The M-Disc BDXL format supports storage of up to 100GB per disc, so it can hold a decent amount of important data.
The only downside is that the original maker of the M-disc media went bankrupt a few years ago. The media is expensive, and is slowly disappearing from the market (I've seen Verbatim M-disc media, but most sellers don't keep a lot on hand).
I have some M-DISC Verbatim spinddle DVD discs but I wanted to buy more drives and I can't find them on any website
If I buy internal SATA drives today and in the future will I be able to use the PC with USB or USB-C adapters or future formats?
With optical discs, you are almost certainly stuck with current formats - there likely won't be new ones because the technology is being phased out by streaming services. Only way this will change is if they make a breakthrough on media storage density (and I don't know if anyone is even studying it anymore after M-Disc).
If you are worried, pick up an external SATA to USB enclosure for optical drives. I bought a NexStar enclosure about 4-5 years ago that works absolutely great for optical drives (though, granted, I haven't looked closely at the newer models, so I don't know about the quality).
At some point, keep in mind there will be new archival technologies and you'll eventually want to transition your backups to them. If your Internet connection is fast enough for cloud storage, that is a good place to store encrypted intermediate backups.
As far as M-Disc compatible Bluray burners go, here are a few I found with a quick search (keep in mind some don't include software):
https://www.newegg.com/lg-wh16ns40-internal-blu-ray-burner/p/N82E16827136269
https://www.newegg.com/pioneer-bdr-2212-internal-blu-ray-burner/p/N82E16827129092
https://www.newegg.com/asus-bw-16d1ht-internal-blu-ray-burner/p/N82E16827135306
https://www.newegg.com/pioneer-bdr-212dbk-internal-blu-ray-burner/p/N82E16827129091
And, BTW, a laptop Bluray burner with M-Disc support will work just fine with a desktop (either with an external USB enclosure or via a bay adapter).
Internal 5.25" to slim optical drive adapter:
these cases for optical drive are very expensive for me, bluray drive is also very expensive so i bought DVD drives and media but i can´t find any more mdisc dvd
Amazon and Newegg sell the media, among others, but it is expensive. Most of what is available gets snapped up by companies that use it for for archival backups.
If you can't afford it, that is a problem for your plans. You might want to look up the cost of multiple cloud storage providers in your area as in the long run it might be cheaper (depending upon how much data you have to save).
What links mdisc dvd verbatim or mdisc dvd? i buy
M-DISC DVD Smartbuy is reliable? I only used Verbatim's M-DISC DVD but I look for the cheapest spindle
https://www.amazon.com/s?k=m-disc+media&ref=nb_sb_noss_2
https://www.newegg.com/p/pl?d=m+disc+media&N=100007591&isdeptsrh=1
https://www.cdw.com/search/?key=m-disc media
Heya,
Doesn't matter if you use internal SATA or external USB based BDR writing drives; you're going to want to write them slowly and with validation to ensure a good copy is made, so expect to write at 2x basically (4x can work, but any hiccup and you won't validate 100% of the time). The internals are pretty inexpensive and will do the job. The BDR media will last a long time. M-disc is another option, more expensive, but it will last your lifetime. The idea of worrying about a drive capable of reading these discs in the future is totally unfounded. You'd think we wouldn't have any drives capable of reading CD's and DVD's at this point, being we've had them for 30 and 40 years respectively at this point approximately and they're still the top affordable choice for long term archival storage as a media over hard disc. BDR discs at 25Gb, 50Gb and 100Gb are quite common, inexpensive and will last a very long time. Survive longer than a hard disc or SSD will, at this point. You'd think there wouldn't be drives for sale, 40 years later, than can read CD's. Yet there are. There's no reason to believe any CD, DVD or BDR is going to be scarce to find a drive to read them in another 20, 40, etc years. Optical archival is going to be important for many decades to come. Anyone who thinks a non-volitile version of solid state will take over is just tech-wishing because no one will store anything important on media that can be wiped by natural and man-made events that involve intense magnetic waves. Your optical stuff, etched into stone basically (m-disc) will be the better solution for now. The other alternative is tape drives. Tape is still a thing, viable and still used. Still drives available to read them too. This stuff isn't going anywhere any time soon.
I currently archive data with:
LG WH16NS40 BDR drive (internal SATA)
Verbatim 100GB BDXL M-Disc drives (5x pack)
I use IMGBurn software (free) at 2x write with validation.
Not a coaster made yet. All read in alternative drives perfectly.
Store in fireproof, waterproof case and you're set.
I do this as my 3rd and 4th "physical copy" options in a 1, 2, 3 + scheme for "backup."
Very best,
