Greetings. After installing a new SSD and reorganizing the use of my SATA ports, everything seemed fine for two days. Then, on boot, chkdsk started out of nowhere, but apparently testing my storage HDD.
It fixed index problems, and now it's going file by file with the messages:
- copying orphaned file ____.__ from directory xxxx to xxxx (or something like that)
- insufficient disk space to recover lost data
This has going on for 16 hours and counting.
I had moved this drive from a Marvell controller to the native port, and it seemed ok.
Any tips? Should I stop the chkdsk and try to boot again?
It may be something obvious, but tension is not allowing me to think clearly.
Any input is appreciated. Thanks.
