Originally posted by: iAtticus
I'm not going to buy a after market cooler...
I have some AS5 and AS Cleaning solution...
If I apply some AS5 to the stock heatsink will it improve temps?
Okay, this is my OPINION, so take it for what it's worth...
Personally, I don't think it will make much difference, as long as you applied the grease correctly the first time.
Secondly, the whole idea of grease is to compensate for microscopic surface defects. It won't do anything if the TIM isn't flat. As a matter of fact, it will act as a heat insulator. So, check and see if your cooler needs to be lapped.
Thirdly, I prefer Scythe MX-1 over AS5, for all sorts of reasons. However, any grease will work, as long as you apply it correctly. A lot of times, it just comes down to 'bragging rights'. So, if you use Radio Shack thermal grease, just don't tell anybody, and you'll be fine!
Speaking of which, I *think* 'AS Cleaner & Purifier' is just repackaged Goo Gone and iso alchohol (respectively). If you haven't opened them yet, I would return it and get a 59-cent can of paint thinner (mineral spirits) at Ace Hardware. That's what I use and it works great -- even recommended on the Arctic Cooling web site...
Source
If you do not have ArctiClean, use a xylene based cleaner, (Goof Off and some carburetor cleaners) acetone, mineral spirits, or high-purity isopropyl alcohol.
