So, I previously owned the following rig (before UPS smashed it during shipping to my new place):
AMD A64 X2 4400+ (S939)
Abit AN8 32X
2x1GB OCZ DDR 500
GeForce 7900GTX
74GB WD Raptor
550W Antec True Power PSU
LG DVDRW
Lian Li PC60 Case (2x80mm front panel intake, 1x 80mm top outake, 1x back panel outake, PSU outtake)
Firstly, the system was NOT overclocked at all. Any time the system was put under full processor load (that is to say both cores forced to work at 100%) the following problems occured:
CPU temp spiked close to 75C
the PWM section of the motherboard monitor would spike to over 90C and cause a system shutdown due to overheating. The PWM was also connected to the north bridge via a heat pipe, so its possible the heat was coming from there.
I tried removing the CPU heatsink, cleaning off its initial thermal grease/pad thing and using AS5 and the CPU temperature went down a bit, but still spiked near 73C (I tried one last time with AS5 incase i didnt apply well and again, same problem).
So my question then becomes... Is stock cooling nolonger sufficient with newer processors?
I am forced to replace my computer that UPS damaged, and I think im going with one of the core2duo chips. Am I going to have overheating problems with this? Do I need to move to aftermarket air coolers (not just for the CPU but for the bridges and PWM areas too?)... Should I liquid cool? I likely wont be overclocking, but I do frequently run my systems at full load, and I dont want it overheating or having temperatures getting out of hand.
Any thoughts/suggestions?
Thanks,
Brett
Abit AN8 32X
2x1GB OCZ DDR 500
GeForce 7900GTX
74GB WD Raptor
LG DVDRW
Thanks,
Brett
