Originally posted by: bryanW1995
I know that mine is off b/c i'm pretty sure that there's the so-called "2nd law of thermodynamics", and it says that my case can't be cooler than the air around it unless something is making it that way. like, I dunna, a vapochill ls or something. While it is certainly possible that my wife snuck one in there and disguised it as an extra hard drive, I doubt it. um, put another way, ambient is 24c and idle is 19c. OP's chip idles at almost exactly the same temps as mine. I believe that the tjunction is supposed to be 100 instead of 85, so it throws most sensors off by 15c. those are pretty crappy load temps. mine doesn't even load that high at 3.48 with good aftermarket cooling.
Well at least one person commented on the temps.
I am using the stock cooler with freshly applied artic silver 5.
And those are crappy temps?
I think the temps are bad b/c if you add 15c to both then you're idling at 33c and loading at 56c. that is probably ok for stock cooling, but stock cooling is terrible. I'm at 33c idle right now and run high 40's night and low 50's day (south tx middle summer) load on my e6750 with a tuniq tower at 3.48 and 1.48 vcore.
"Those temps are off by more than 15C I would say. Under load the temps should he higher than idle. If you add 15c to 18C its still lower than reported idle which doesn't look too far out of whack. That cant be"
what do you mean skot? he's at 17/18 at idle and 41 load, showing tjunction 85. tjunction is actually 100, so he's really 32/33 and 56. you can change coretemp to display offset from tjunction to verify this. on mine at idle it shows 18c, but if I display tjunction offset it shows 67c. Since tjunction is actually 100c then I KNOW that I'm at 33c, not 18c. He has the same chip and it could not have been made very far in distance or time from mine and both are new release G0's, so odds are his is also off by 15c.
