SparkyJJO
I bought a house last month. The well water is hard, and has iron and sulfur in it. There is an old Culligan softener in the basement that is probably around 10+ years old.
I installed a 20" big blue filter housing with a KDF85 cartridge, which pretty much eliminated the iron and sulfur problem on the cold water. I can actually drink it straight from the tap and the toilet bowl doesn't turn orange after a couple days, so that's great.
I drained the 40 gal hot water tank and refilled, so my hot water no longer stank either. Everything was hunky dunky for nearly 2 weeks.
Recently my hot water has started to stink yet again, although it doesn't stink quite the same as it used to. It isn't quite as strong (yet?) but the odor is also a little different. I'm single so I don't cycle the water through the tank that quickly. It is an electric tank, around 3-4 years old.
Recommendations I have been given:
1) pull and cut off the anode rod. But that would cause the tank to corrode faster?
2) soak the tank in bleach to kill off anything in the tank, then flush it out. May or may not be a permanent fix.
3) replace the tank. I don't really want to do this as what's to say that the problem won't come back since I don't know the actual cause?
4) ????
Anyone else run into this, and if so what was your fix?
Side note - I don't think the old softener is doing its job since I just put a new kitchen sink in this week and the amount of water spots is ridiculous. Some are almost crusty. I'm going to get the water before/after the softener checked.
4) ????
