Still need help solving this problem
lillazy23
Banned
Feb 16, 2001
149
hey guys i need serious help, heres my rig hope someone could help me with my problem
AMD 1.2 (not oced) CPU heat idles at (48-49) and (52-53) under load
A7V133 (Bios 1004)
Asus geforce2 V7700 GTS (latest detenator drivers from nvidia)
SB live X-Gamer (latest drivers from creative)
Kingston NIC card (latest drivers)
Via4in1 driver 4.29v
promise ata100 driver updated
300watt AMD approved PSU
Ok problem is I keep freezing when im playing counterstrike. Sometimes it takes 30 min or an hour but i eventually will freeze. I have tried every setup but cant fix it. First I thought it was a IRQ conflict i looked into that and found out that sb live was sharing IRQ with NIC card, so i moved SB live to PCI slot 3 and assigned it to IRQ 5 by itself. And the NIC card is on slot 4 sharing IRQ with USB controllers. If I change the IRQ for the NIC card the USB controllers move with it. So I disabled COM 3 and assigned NIC card to IRQ 3 sharing with USB controllers.
heres setup
00 sytem timer
01 standard 101 microsoft natural keyboard
02 programmable interrupt controller
03 Kingston EtheRX PCI 10/100 Fast Ethernet Adapter
03 VIA tech 3038 PCI to USB Universal Host Controller
03 ACPI IRQ Holder for PCI IRQ Steering
04 Communications Port (COM 1)
05 Creative SB Live! series
05 ACPI IRQ Holder for PCI IRQ Steering
06 Standard Floppy Disk Controller
07 ECP Printer Port (LPT1)
08 System CMOS/real time clock
09 SCI IRQ used by ACPI bus
10 Win 95-98 Promise Ultra100 IDE Controller
10 ACPI IRQ Holder for PCI IRQ steering
11 NVIDIA Geforce 2 GTS/ Geforce2 Pro
11 ACPI IRQ HOlder for PCI IRQ Steering
13 Numeric data processor
14 Via Bus MAster PCI IDE controller
14 Primary IDE controller (dual fifo)
15 Via bus master pci ide controller
15 secondary ide controller (dual fifo)
I have also learned that slots 4/5 automatically use IRQ for USB controllers, slot 1 uses video card, and slot 2 uses promise ata100. So that leaves me only slot 3 to use, I dont know if its the NIC card and the USB controllers causing the problem or Sound card. I forgot to mention i have a USB microsoft optical mouse which might cause problems with the NIC card. Its either Sound card with USB controllers or NIC card with USB controllers. And i have tried both setups and both dont work. I cant use slot 2 because of the ata100 and slot1 is used by the video card. I have tried looking for a way to change the USB controllers to a different IRQ but cant find it. Anybody know if this is possible on the A7V133 mobos??? Also I have done some tests to see if it was a heat problem runining seti@home and comp was doing fine. And did a test on 3dmark and passed all tests. Dont know what else to do, I hope someobody out there can find the problem.
THANK YOU FOR ANY HELP
Joemonkey
8,859
4
you don't mention which OS you are using (or maybe you did and i overlooked it, i've been drinking)
i'm running win2k, and CS would lockup as well, and drive me fekkin' CRAZY.
best fix i've found is to use the 6.18 detenator drivers, and nothing above or below... had no problems with CS or any other game. best way to find is to click here
WDCentral
188
I had the same exact problem as you did in Windows 2000 using OpenGL in Counter-Strike. I tried just about everything. The last thing i tried was updating my BIOS (i had an abit board). I think there is a 1006 BIOS release isnt there?? i dunno maybe i am crazy. I haven't played CS for more than an hour since then but no crashes. I am going to go play CS now and I'll try to report back.
lillazy23
Banned
Feb 16, 2001
149
im using win98se, which driver is the newest one??? i download the detenator from nvidia site. would that be causing the problem?
MCS
2,519
Did you install Windows fresh with this hardware or did you just upgrade and let Windows reconfigure itself?
