still looking for an heaphone adapter for hp1910...found one, but might not work, help!
dpopiz
I posted before asking about where to find a 2.5mm male - to - 3.5mm female headphone jack adapter, so that I can use normal headphones on the hp1910 pocketpc. I finally found one here
http://www.markertek.com/MTStore/product.CFM?BaseItem=AA221
but I think it might be too big circumference-wise to go all the way into the 2.5mm jack on the 1910. look at the jack on your 1910 if you have one, you should be able to see what I'm talking about.
I'm looking for an adapter cable now, so that it will be small enough to fit the jack.
um.. hold up. let me find the link
I used to own a 1910
k found it.
here
Check the bottom of the page, normally $3.99 each + s/h but minimum order is $11.50
Or you can buy it off this guy here.
he's selling them for $6.99 + $2.99 s/h. Bascially ripping you off. It's up to you.
what I did was buy 6 from the first link and sold them $5 s/h to some people on brighthand to make up for the cost. I believe the guy on eBay is ripping people off but a lot of people have purchased from him.
