According to SpeedFan, my computer idles at 38c-40c, and peaks at no higher than 49c on load. Here are specs:
Lian-Li PC-1200b plus
Zalman CNPS9500
AMD Athlon 4200+ x2
Asus A8N32-SLI Deluxe
eVga 7900 GT
2 gig Mushkin ddr400
The ram sits right in front of the intake to me cpu fan. So, it seems that hot air is being sucked and pushed through the heatsink.
I have updated the BIOS, and that dropped my temps a couple of degrees to the ones stated above.
I read so many reviews of this heatsink, and they all said that the Zalman was amazing. Most places also reported much lower temps than I am getting.
My friend has the same processor as I do, with a Thermaltake big Typhoon, and he idles at 29c. I am beginning to wonder if this isnt a bios issue. My heatsink isnt even warm to the touch-not even at the base.
I am also kind of disappointed with the Lian-Li case. There is no intake for the main components, and the power supply sits in its own little "cubby". My fault on that one.
My friend and I have spent hours trying ti figure this out with no solution whatsoever.
Anywho, what could be the problem?(if there is one)
Thanks in advance.
Zalman CNPS9500
AMD Athlon 4200+ x2
eVga 7900 GT
Thanks in advance.
