Still having problems with my 6800NU
Chosonman
I've unclocked it and set everything back to factory settings and I still get occassional artifacts and a total graphic melt down. I see the screen steadily filling up with white stuff then my screen turns black then to BSOD.
I thought I had the problem solved last night when I played CS:Source for a few hours without any problems. But I booted up this morning and as I was surfing the net it all started again. It's like a nightmare now. I'll be surfing then I'll notice a few small flickers. Then slowly and steadily the screen will fill up with broken white lines and then BSOD...
I'm at a loss. Who can help me?
I highly doubt it's your power supply. It just sounds like an error that there's nothing you can do about. A 6800nu is only supposedly to have 12 pipes, getting 16 pipes is a bonus. I'd probably revert back and just use it with 12 pipes. Unless it still does the same thing, I'd try to RMA it. Even though that might be impossible now that you've flashed the BIOS..?
when you brought it back to stock did you uninstall Riva or did you flash the vid cards' bios? Stock heatsink and fan on the GPU?
