- Jul 3, 2005
- 594
- 0
- 0
I don't know if any of you remember my last thread about troubles with WinXP file system corruption; thanks again to all those who replied.
But to cut the story short, I have a dual boot system, but WinXP file system (NTSF) was corrupted on the entire Win boot partition, so I had to eventually reinstall.
So I did that last night, and naturally, Windows install overwrote the MBR that supported the bootloader; Windows was working fine at that point, and I attempted to get dual boot going again, wanting to avoid reinstalling Linux (that would be way too much to backup.)
So I did grub-install and all the rest of the sha-bang with a Fedora recovery disk, and GRUB worked once again, and Linux booted up as normal. But when I tried to boot into the freshly installed Win OS, it gives me the error message something to the effect of:
NTLDR files missing
So I copied the \i386\ntldr.exe file back into D:
(another point is that since Windows crashed, one of the NTSF data partitions has become C:, and the original boot partitionis now D:\, not wanting to wipe any data clear, I asked the installation to be done on D:\)
And now it tells me that boot.ini is missing.
At this point, I have tried a lot of different things, and don't really know where to go from here.
Does anyone have a solution to the current problem, without having to reinstall either OS?
If not, does anyone have a solution that allows me to reinstall Windows again, but in the process of reloading GRUB safely after Win installation, not change anything so as to allow windows still to boot normally.
the boot.cfg file I have is:
Thanks in advance;
--HB
NTLDR files missing
Code:
default=0
timeout=5
splashimage=(hd0,2)/boot/grub/splash.xpm.gz
hiddenmenu
title Fedora Core (2.6.11-1.1369_FC4smp)
root (hd0,2)
kernel /boot/vmlinuz-2.6.11-1.1369_FC4smp ro root=LABEL=/ ide=nodma rhgb
quiet
initrd /boot/initrd-2.6.11-1.1369_FC4smp.img
title Fedora Core-up (2.6.11-1.1369_FC4)
root (hd0,2)
kernel /boot/vmlinuz-2.6.11-1.1369_FC4 ro root=LABEL=/ ide=nodma rhgb qu
iet
initrd /boot/initrd-2.6.11-1.1369_FC4.img
title Windows XP Professional
rootnoverify (hd1,0)
map (hd0) (hd1)
map (hd1) (hd0)
## rootnoverify (hd0,0)
savedefault
chainloader +1
makeactive
title Other
rootnoverify (hd2,0)
chainloader +1
Thanks in advance;
--HB
