Stereo wont work!
Thornburg 85
I am tryinf to install a new stereo in my 2004 saturn ion but I cant get it to work. Ive tried everything possible. The wires in the saturn dont match the stereo. I can't seem to find the ground wire in the car. N im not sure if I'm hooking up the yellow and red cord correctly either because the car has 2 yellow wires.
mindless1
8,850
1,817
Whip out your multimeter and take some voltage readings between various wires and ground.
You should have a constant power 12V for the clock/memory, and a 12V on with accessory/ignition for the main 12V stereo power.
Ground, you can check resistance to a (any) chassis ground point.
You could instead find the factory wiring diagram and compare to where the wires went on the old stereo.
Is the factory wiring intact still or hacked up? If intact, you might check major stereo brands for an adapter harness. Even if your brand of stereo is not supported, you can hack up the adapter harness to your new stereo wiring to leave the vehicle wiring intact, then just plug the intact vehicle wiring connection into that adapter harness.
If this diagram is correct it might help:
More here: https://www.justanswer.com/car/0a2x4-2004-saturn-ion-quad-coupe-installing-new-stereo.html
