Stereo Audio Extension Cable for Samsung smartphone
ZenChip
Hello everyone,
I have an Samsung Galaxy S3 Neo phone, and I enjoy listening music on it. I had a pair of earbuds (Samsung HS130) but I managed to destroy the cable because I keep my phone in the pocket of my jeans, and every time I walk or sit down, the cable gets squeezed and in after a while the wires break.
The wire breaks right at the connector (jack), and I was wondering if other people had this problem. I am trying to find a Stereo Audio Extension Cable (also called Audio Extender), preferably with an L-shaped jack, in order to prevent damage, or at least with some more resistant (thick) cable.
I broke two pairs of earbuds already and I don't want to destroy the next one. I tried with a standard extender for speakers but it doesn't work.
The Audio Extender should preferably be 10-20 centimeters (4-8 inches), not larger. So I was wondering if such Audio Extender compatible with Samsung earbuds exist. It's connector is a bit more sophisticated than the 3.5 mm standard connector.
Thanks
I think this is what you're looking for. It has the extra third ring on the jack that you need. Or search Amazon for a TRRS 3.5mm extension cable.
Thank you very much for the answers.
For the record, I will write down the name of those cable, so other people looking for the same thing will know more about what to search for (when the above links will disappear):
- 3.5mm Male to 3.5mm Female Auxiliary 4-Conductor TRRS Stereo Audio Extension Cable
- 6 inch 4-Pole 3.5mm Male Right Angle to 3.5mm Female Stereo Audio Cable
- 15cm Stereo 3.5mm (1/8") Male to 90° Right Angle Female Plug Adapter Converter
