This car is beginning to drive me crazy.
Been having an issue with the steering, where the wheel does not smoothly return back to center after a turn at low speeds, particularly noticeable in a parking lot and such. It'll usually get caught up at 90 degrees or so, left or right, even if its already at full spin.
For example, if I turn all the way to the lock, and let go as I move, itll get caught up several times at 90 degrees several times as it revolves back, sometimes requiring a bit of manual help to get it past the trouble spots.
The mechanic I brought it to had the steering rack replaced under warranty.
Now, the steering is much tighter overall, although he says thats due to it being a new rack, and it needs some time to loosen up. The problem with it getting caught up still appears to be there, although the pull towards center is now stronger.
But a new issue is that the wheel now turns more in one direction than the other. It tracks perfectly straight when the wheel is dead center, but I can turn about 90 degrees more or less in one direction than the other. I'm not 100% sure, but I think it turns more in one direction than it ever did, rather than less.
So I'm guessing the new rack wasnt installed properly?
And could the wheel getting caught up issue be a power steering thing after all, rather than a mechanical part of the steering?
