To my eyes, my 17inch Nec Multisync 75 seems to be a very good monitor. Good colors, good picture quality, etc. But i find it a little small. I would like a larger monitor, but I do not know if I should go the LCD's way...
I play a lot of game and my wife likes to surf on the net, play with Printmaster, etc. So, good picture quality, text clarity and good colors are a must. How does a monitor like the Viewsonic VX922 or the Samsung 931C compare to a Nec Multisync 75 ? Will i just gain in size and loose on all the other fronts ?
Another question : as my computer is usually not very high end (amd 3200+, 7600gt with a videocard upgrade planned next year) I was looking more on the 19inch monitor side (if i decide to change). Would a 20inch one, with a higher native resolution would be a bad choice in my budget limited system ?
Thanks for your insights...
