Static on my car stereo with the radio. CD Player works fine though.
Status
Not open for further replies.
frankqfrank
1,040
Cadillac Deville Concours, 1995. It has a CD/Tape Stereo and theres static heard when I listen to the radio, but not on a tape or CD. I have no idea why this started happening. It's bearable but still totally noticable.
The only parts of the system I have access to is the actual player in the dash and the antenna mechanism in the trunk.
Thanks in advance.
FrankWhite21044
23
i used to have an eldorado and one time after loading up my trunk, i must have thrown a box right on the antenna cable and pulled it out of the mechanism. check that and check on the back of the head unit that the cable is plugged in all the way.
another thing, does the static change in sound as you drive? ie get higher pitched as you accelerate. if thats the case, certain parts actually emit radio waves when they need to be replaced. i forget what exactly but i had the same thing happen.
randomboy
668
Check the radio connection at both the antenna in the trunk, and where it plugs into the HU.
Jeff
LiLithTecH
3,105
If you have someone at a dealer you can talk to ,
GM Serivce Bulletin
539602 JUN 95 Radio - Excessive AM Static Noise with Engine Running
corkyg
Elite Member | Peripherals
27,370
239
Yep - you have an antenna problem - and there is a filter circuit that is involved. It may have given up the ghost.
randomboy
668
HU = Head Unit = CD player = radio = tuner = am/fm reciever = whatever you wanna call it :)
jeff
Puffnstuff
16,187
4,871
Is it the factory radio or aftermarket? CorgyG is correct about a filter and I've used them on older cars to eliminate electrical noise from radios. Radio shack carries them and you just splice them into the power line.
corkyg
27,370
239
Why respond to a 14 year old necro thread?
Burpo
4,223
473
Maybe he was checking to see if you're still here Corky.. I for one, am glad you still are :)
corkyg
27,370
239
LOL Thanks, but it's a waste of tech space. Thread closed.
Status
