Alright, im sure this almost exact post has been posted before, but I don't really have the time to search for it.
When im at my work, I use XP remote desktop to connect to my computer at home. I am able to do it as long as the IP I chose in port fowarding is the the one that the router gave my computer computer when I started it up. Normally when I wake up and turn on my computer I would just go in and run ipconfig and just change it if needed, but sometimes it resets itself and I can't connect to finish up the work I would be doing.
I was wondering if someone would be able to walk me through making the router assign my computer a static ip that would never change. The problem with it is that it doesn't allow me to assign internal LAN IPs by a MAC address so thats out of the question. I tried setting it up the other day by setting a static ip and stuff but later that afternoon I restarted and it wouldn't connect to the internet. I'm not sure what the problem was but I had to go back to my network card TCP/IP settings and take off the static ip settings and allow it to assign via DHCP again. If some one could post the settings that I need to use to make it work correctly and not give me such problems that would be great
Thanks,
Luc
Thanks,
Luc
