Problem Solved:
Put the Sata drive on a black connector and all is well.
This is part of a new install where I am having trouble getting older 40gb IDE drive and 500gb SATA drive to coexist.
On boot the computer pauses and says 'No IDE Master HDD Detected - Press F1 to Continue'
When I hit F1, WinXP Pro startups off of the drive it said was not detected. When I go to Computer Mgmt, it shows both drives. I run diagnostics on the 40gb drive and it shows it as the Master on the IDE cable and the DVD drive as the slave. The utility says the drive is operating properly.
I am running the latest BIOS for the MB.
I have the 500 gb drive on SATA 4 - which is a data channel.
In the Bios I have JMicron SATA/PATA Controller Enabled, and JMicron SATA Controller Mode set as IDE
If I unplug the SATA drive, then the computer boots up without issue or pauses.
Very baffeling.
Please help.
Very baffeling.
Please help.
