Startup Frozen and Problems with Win 2000 Repair Installation...
Turk911
I ran a repair installation a few days ago, but after one use, the computer froze on startup. The specific screen is the "starting windows" screen, it also has an option to press F8 "for troubleshooting an dadvanced startup options for windows 2000", but when pressing F8, nothing happens. I tried to run a repair installation again, but I do not get the same options as I had a few days prior. I don't know why it doesn't give the same options, but both times the computer had a different problem. The first time, I got a blue screen with an error and the repair installation worked fine, retaining all my data and programs. The second time, it just freezes on startup, but the options for repair installation are not quite the same. These are all the options I get...
1)Welcome to Setup:
-To setup windows now, press Enter
-To repair a windows 2000 installation, press R
After pressing "Enter"
Agree with End-User License Agreement?
"F8"
Shows existing partitions and unpartitioned space on computer
-To set up windows 2000 on the selected item, press Enter.
-To create a partition in the unpartitioned space, press C.
-To delete the selected partition, press D.
C: NTFS (41G DataC)
D: FAT32 (118G DataD)
2)Welcome to Setup:
After pressing "R"
Windows 2000 Repair Options:
-To repair a windows 2000 installation by using recovery console, press C.
-To repair a windows 2000 installation by using the emergency repair process, press R.
After pressing "C"
Microsoft Windows 2000 (TM) Recovery Console.
The Recovery Console provides system repair and recovery fanctionality.
Type EXIT to quit the Recovery Console and restart the computer.
1:C:\WINNT
Which Windows 2000 installation would like to log onto
(To cancel, press ENTER)?
3)Welcome to Setup:
After pressing "R"
After pressing "R"
This operation will attempt to repair your windows 2000 system. Depending on the type of damange present, this operation may or may not be successful. If the system is not successfully repaired, restart Setup and choose the option to recover a destroyed system and system disk.
Select one of the following repair options.
-Manual Repair: To choose from a list of repair options, press M
-Fast Repair: To perform all repair options, press F
After press "M"
As part of the repair process, setup will perform each optional task selected below.
To have Setup perform the selected tasks, press Enter.
To change the selections, use the UP or DOWN ARROW keys to select an item, and then press Enter.
[x]Inspect startup environment
[x]Verify windows 2000 system files
[x]Inspect boot sector
Continue (perform selected tasks)
you need an Emergency Repair disk for the windows 2000 installation you want to repair.
NOTE: Setup can only repair windows 2000 installations.
-If you have the Emergency Repair disk, press Enter.
-If you do not have the Emergency Repair disk, press L. Setup will attempt to locate windows 2000 for you.
After press "F"
These are all the options I get, these are not the same options I had when I performed the last repair installation. My main objective is to maintain all my data in my Drive C. I have a ghost image of my operation system, I want to move all my important data from Drive C into Drive D before I install my ghost image. To do this, I need to get my current operating system to work and be able to transfer all the data.
amdskip
22,530
13
Easy way, pull the drive and put it in a ubs enclosure or another computer, pull the data off, use the image to set the drive back up.
