My system is starting to get flaky and I'd like thoughts on whether I'm dealing with a single or multiple problems
System
Shuttle AK31 (266A)
2 PC2100 256M Crucial DDR
Athlon 1.4Ghz
IBM deskstar 80gig in 2 partitions
GeForce 3
Audigy Sound card
floppy, DVD, monitor
300 W PS
Windows XP (Fat32 file system)
all drivers up to date, I'm not overclocking.
Okay, I built this thing in October and for the first several months it ran great; I don't think I had a single crash for 3 months (never had that happen with a windows system before). Then I started getting periodic crash to desktops. Also, if I had to reboot the system, it would often lock up on a plain blue screen; a cold reboot would result in a disk scan during the boots, and frequently a bad sector would be identified. This happens on 60-75% of all reboots. I have defragged both partitions and run scans, but I'm not sure how to run a surface scan of the disk (utility seems not included with XP).
But I could live with that. Today, as I was working on a document, I heard what I think was an audible popping sound and the monitor went blank, and immediately I heard a single repetitive tone from the case (like a post failure: is there a singificance to the pattern of the tones? This was just a single 2 second tone, repeating). Uh-oh. So I powered down and rebooted from cold start and sure enough, POST failure. I started reseating cards and when I pulled the 2nd DDR and rebooted it failed, but when I pulled the 1st DIMM and place the second DDR into the first slot, the system booted. I then placed the (? faulty) DIMM into the second slot and the system again booted fine. I am running default memory voltages and timings.
Here are my questions
1) Can I explain a lot of my systems problems with a flaky DIMM? If so, why am I getting bad sector problems on the hard drive?
2) What happened today? I'm writing it off to dust in the contacts, is that reasonable?
3) How do I do a detailed scan of the hard drive and have the bad sectors marked so Windows doesn't keep writing to them (at least, I'm assuming it's the same bad sector as opposed to steady detrioration of my hard drive).
Thanks for any thoughts!
Yours,
John Respass
System
Shuttle AK31 (266A)
Athlon 1.4Ghz
GeForce 3
Audigy Sound card
300 W PS
Yours,
John Respass
