Hi there. Glad to be here. Lots of great info. Its been 5-6 years since my last build and my P4 system is way too slow. So I'll be building a new one.
HERES MY GOAL-
Priority #1: Stability, reliability, longevity.
Priority #2: Extremely fast, high performance.
Main usage: Business system with very small client database, casual vid/photo edits, casual gaming.
Misc: I don't plan to overclock, I'll run Win-7 x64, I'm targeting a budget of $1500-$2000.
After READING DOZENS of threads, I'm still confused on several points.
Heres the narrowed choices I have for several items:
CPU - i7-950 (already on the way)
MOBO - Asus Sabertooth x58 vs. Intel DX58O2
- Which will run cooler?
- Which will be easier for a basic non-overclock set-up?
- Which is likely to have a longer lifespan?
RAM - Mushkin vs. Kingston
- 1333mhz vs. 1600mhz
- 6GB (3x2GB) or 12GB (3x4GB)
- XMP support or manual settings
- Should I worry about latency?
HARD DRIVE - Crucial RealSSD vs. Intel X25M
- SATA II vs. SATA III.
- Will SSD have the longevity of a standard HDD?
- Any ideas for a secondary standard HDD thats reasonably quick?
Case - Lian-li PC-V1020 vs. Antec Nine Hundred Two
- Big cost difference...
- Will one cool better? (alum vs steel)
- Will one be easier to work in?
Video Card - Asus ENGTX460 vs. ATI ???
- Several forums stated that the Asus card ran very cool...
- Any other suggestions; cool, stable, etc...
Power supply - Antec - TP-750 Blue vs. ???
- Will 750 watts suffice?
...Honestly, while searching online, I found alot of conflicting opinions.
...I've even called manufacturers more than once and was given different part numbers and different advice each time!
So its hard to determine what'll be best for me... Any help would be greatly appreciated! Thanks.
Jared
HERES MY GOAL-
Jared
