- Mar 1, 2007
- 282
- 3
- 76
When I bought my car, the previous owner said it had a drain that would kill the battery within five hours. As soon as I got it, I found a small 90mA draw, pulled out the aftermarket bluetooth system and the draw was back to the expected 10mA. After a few weeks, the battery was holding its charge - I thought the problem was solved.
I've driven the car more in the past few days, and the draw is back. However, it's not being caused by any fuses; a few wires are connected to the positive terminal and the one causing the 2.7 amp drain seems to be connected to the starter or the alternator. If I remove this wire, I hear a click and the engine doesn't crank, but everything else works. If I leave the wire connected, start the engine and then remove it, the battery voltage drops from 14V to 12.5. At first I figured it was the starter, but the second test led me to believe it was the alternator. I'm not able to follow the wire to its source but if it is the alternator, I can't understand why the starter wouldn't work with the wire disconnected.
Are there any ways to figure out which of these components are at fault? Some googling seems to confirm that either a bad starter or alternator can cause a drain but I'm not sure, so I'm appealing to the sage minds of ATG for help.
