Start up problem
Marcq
Guys, my dads pc won?t start on the first attempt, no video out signal, no bip, nothing, just the fans are working. It will only start on the third try, after that, he can shut it down and start up again no problem. But if he leaves his pc shut down over night the next day the same problem occurs and it seem to get worst, this morning it took him four attempts to get it started, what could be the problem?
Thanks, Marc..
The problem just occurred lately. It?s a amd 233 voodoo3 196 arm, owned it for 3 years.
I was thinking a faulty P/S
Marc..
I saw a rare occurance where one of the traces on the mobo had developed a slight crack, just enough that when cold it wouldn't start, once it had warmed up slightly, the trace would expand to make contact, and would boot and restart no problem.
If you have a meter, you could check out your psu. Have you tried removing everything and reassembling the comp to make sure that all the contacts are clean (this means the cpu too )?
The symptom you are describing is often an indication of a degrading power supply.
Power supplys take a finite time to ramp up to the specified output voltages. If some thing changes this ramp up time, like an increased resistance in the path, the processor may not start on the first try. If using the reset switch, or pressing the on off switch rapidly, allows the system to start, then the power supply has now reached the required voltage level. If it is taking a few tries, the power supply is probably ready to quit.
Thanks guys, yes it was the P/S, it died this morning, I guess it was due, after ten year of hard laber
Marc..
