Kelemvor
Howdy,
I have 4 PCs that I want to put Starcraft on to use for a small LAN party. I know SC has the "Spawn" install thing but do I have to use that?
If I install the full version on each PC using the same CD key and then make a TCP/IP game, will I get an error because all computers use the same key? Reason I don't want to Spawn is that you are then limited to the original SC and can't Spawn with Brood War.
Has anyone tried this before and if so, what did you do to get SC:BW to work on LAN games? I don't need to be able to go to B.Net at all...
Thanks.
Thanks.
