Staples Gel Stick Pens, Dozen & Staples Ballpoint, 2 Dozen $0.96 at Staples
eunsang
237
Get 3 Dozen Staples Pens (1 Dozen Gel, 2 Dozen Ballpoint) for $0.96. Free shipping on $50+ orders. Staples
Use the "Order by Catalog No." function and add ONE of the following items to cart:
555124-T7 (Assorted Gel, Dozen) - $1.98
501954-T7 (Blue Gel, Dozen) - $1.98
501955-T7 (Black Gel, Dozen) - $1.98
Then choose TWO from the following: 474300-LV (Blue Ballpoint, Dozen) - $0.49
474303-LV (Black Ballpoint, Dozen) - $0.49
then lastly, add couple to take off $2 off your total. coupon can be found here.
Like it said, some of you might not get free shipping. I got free shipping for some unknown reason.
Thump553
12,839
2,625
I've bought two dozen of the Staples ballpoint pens before, but never again. They are about the worst quality pens I have ever seen-constantly skipping, etc. If you buy them to fill out an order, you might as well just throw them away when they arrive.
statik213
1,654
to get free shipping, sign-up for staplesrewards:
https://www.staplesrewardscenter.com/SORC/UserManagement/Login/Login.aspx
then go to staples.com -> login -> change acount info -> continue
enter ur staples reward number on this page (around the middle of the form) click continue
then order by catalog.
good luck!
more stuff from FW:
$0.49 cent list, again if you want more cheap stuff
Stap1es paper clips (1,000 pack)
472480-LV $0.49 each (reg. price $1.49)
Swingline standard Stap1es (5,000 box)
112284-LV $0.49 each (reg. price $1.09)
Stap1es magnetic clip dispenser (100-clip capacity)
246199-LV $0.49 each (reg. price $0.98)
claw stap1e remover
482920-LV $0.49 each (reg. price $1.75)
Stap1es #2 soft yellow pencils
327694-LV $0.49 each (reg. price $0.98)
Stap1es letter opener
458232-LV $0.49 each (reg. price $1.18)
Stap1es Tac 'N Stik reusable adhesive
334690-LV $0.49 each (reg. price $1.52)
Stap1es Ideal butterfly clips (box of 50)
103481-LV $0.49 each (reg. price $1.18)
Bic Wite-Out Cover-it correction fluid (20 ml)
521906-LV $0.49 each (reg. price $0.89)
Stap1es ballpoint Comfort Stic Grip stick Pens (medium, dozen)
474303-LV (black), 474300-LV (blue) $0.49 each (reg. price $1.38)
Westcott 12" finger-grip ruler (12" plastic)
786939-LV $0.49 each (reg. price $0.99)
Stap1es poly twin-pocket portfolio $0.49 each (reg. price $1.08)
431489-LV (black)
431490-LV (burgundy)
431488-LV (blue)
431491-LV (green)
Crayola Crayons (box of 8)
445741-LV $0.49 each (reg. price $0.79)
Stap1es pushpins (1/4" plastic heads, box of 100)
224139-LV (clear), 224147-LV (assorted colors) $0.49 each (reg. price $1.08)
Alliance rubber bands (#33, 3.5" x 1/8", bag of 150)
363236-LV $0.49 each (reg. price $1.15)
Storex poly binders (1/2", holds up to 100 sheets)
557123-LV (blue), 557122-LV (red) $0.49 each (reg. price $1.99)
557121-LV (black) $0.49 each
Stap1es 1-hole punch (punches 1/4" holes, 5-sheet capacity)
146308-LV $0.49 each (reg. price $0.98)
Stap1es index card files (black plastic box, holds 250 3"x5" index cards)
122051-LV $0.49 each (reg. price $1.98)
crowderd
170
Deal appears to be dead, unless I'm doing something wrong. All of the first 3 entries are now $4.98 dozen.
statik213
1,654
This deal is abt 2 weeks old, so it probably is dead.
Did you use the order by catalog link?
middlehead
4,573
Clicking on 'Order by Catalog' I get
Expired or Invalid Promotion
The following item(s) are either an Expired or Invalid promotion. We have located these items for you at their regular price.
Another nail in the deal's coffin
