This one has me puzzled, and I'd appreciate any light you folks can shed on it.
Yesterday, my computer froze while I was attempting to unzip too many .rar archives at the same time (stupid work zips one pdf at a time into one archive...each pdf is one page...nice). So I manually shut down the machine, and reboot. I perform a cold start, (I do not have a speaker connected at this point) and the machine starts, and then stops. Turns off, dead. I attempt to restart again. Same result.
At this point, I am troubled. I start disconnecting peripherials, (and connect the case speaker) and I get a sustained boot, finally. When I do, I get a POST error (Long - short short short) (A8N32 SLI Deluxe - AMI BIOS - the only resource I found indicated this is a memory problem). I swap one stick out (2 x 1GB) and boot again. Boots normally, all the way to Windows. I get into Windows, and shut down, and then plug the second stick back in. This time, no POST error (for both sticks) so I start plugging peripherials back in like a happy camper. I connect the ethernet cable. And BAM. Shutdown. Instantaneous. I couldn't believe it, I assumed it was an electrical problem of some kind (bad ground, bad cable - this was a CAT5e cable, the nVidia MAC supports GbE - so I swapped the cable for a plain jane CAT5 to get 100BASE-TX). With the regular cable - same kind of problem, though decidedly less severe (doesn't kill the boot, but it freezes it). I try swapping MAC's (connected to the onboard Marvell port instead of the nVidia) and get the same style problems. Finally, I give up, and boot into Windows without ethernet connected at all. And success.
I connect ethernet cable (to nVidia MAC), and BAM. Shutdown. Again. From a stable desktop. I was mortified/mystified. Could not fathom how this was happening.
I start over again (the next day, as I am stressed by this error). And boot sucessfully into Windows. I connect the Ethernet cable again (100Mbps) and run the system fine...for about 30 minutes. Then it fails. And won't sucessfully boot (POSTs sucessfully, then shuts down for no reason). I disconnect the Ethernet cable again, and it boots sucessfully. This time, I connect to the Marvell MAC, and it is running stable as of now.
What would cause this? Is it some short/burned out circuit/component in the nVidia networking MAC? Is it (2 seperate) bad cables? Is it totally unrelated?
I greatly appreciate any help you can lend.
Athlon 64 X2 4400+
Asus A8N32 SLI-Deluxe
Powercolor X1900XT 512MB
Creative X-Fi Plat
2GB DDR-SDRAM (G-Skill; CL3.0)
620W PSU (Brand eludes me)
Samsung Burner
6 x HDD's of varying sizes
Athlon 64 X2 4400+
Creative X-Fi Plat
Samsung Burner
