- Jun 24, 2001
- 24,195
- 857
- 126
My 2011 Toyota Corolla has always had a weak clutch but it just became a big deal because now it unexpectedly disengages when I accelerate or go up a hill.
When the car was brand new it would shake and shudder I'm first gear when accelerating from a stop under certain conditions... namely, uphill on the coldest winter days. I didn't think it was an issue to deal with under warranty because it only happened occasionally that first winter and only when the engine was cold. If I was in too much of a hurry to let it warm up I would just start slower in second gear for the first few stops on cold days.
After a few years it did get worse where it would start happening on days that were less and less cold but still not when the engine was warm. I continued with the same mitigations.
It also got better when a family member started getting my car serviced with 5W-40 instead of 0W-20. 5W-40 is what Toyota recommended for the same engine in previous year models and only switched to 0W-20 to meet CAFE standards for fuel economy.
It seems that Corollas burn a little bit of oil after production moved to Alabama and mine is one of those Alabama cars. This caught us off guard once when my engine got very low after going way too long between oil changes.
I switched back to 0W-20 Full Synthetic when I started servicing it again and the clutch slipping with a cold engine came back. I tolerated it like I did before, but eventually I had a cooling fan fail and my car overheated a few times before I got it replaced. This seems to have caused the oil to break down prematurely and I ended up almost over a quart low before I noticed back in October. I would just be driving along and when I'd hit the gas in a low gear to pass someone or something I'd feel the car pull for a second or two and then stop pulling as the tach revs up and the vehicle slows until I ease off and let them sync up again, all with no clutch inputs.
So, yeah, I topped off my oil and that problem went away, convincing me that it was somehow related to low/bad oil. I immediately got my oil change (0W-20) and got the cooling fan replaced. My clutch continued working fine for the last two months. Well, "fine" in the sense that it has always been since the car was new (slips from a stand-still when cold).
Suddenly, today, it wasn't "working fine" anymore. I made a turn that immediately crossed some railroad tracks forcing me to delay accelerating until I was past them, but as I tried to pick up speed I felt it accelerate for a second before the engine broke free and revved as if I had used the clutch to disengage it. I reflexively let off the gas and eased back onto it when I felt it "grab" only to have it break free and rev again when I resumed accelerating. It didn't seem to happen when I took the same turn again attempting to recreate it but perhaps that was because me engine was warmer or colder... I dunno considering that I didn't go far before I parked it a bit and doubled back after checking oil and such.
OK, so it's been a fun 8 years on this manual transmission but I think it's pretty clear my clutch is wearing out. If switching to 5W-40 gets my clutch to work normally again, should I just do that or is this something I need to get fixed on another level? Is replacing the clutch even economical on a car like this? It's over 160k miles.
