Standard computer case lock?
The Wildcard
Hi there,
I was wondering what is the type of lock that every standard computer case has? It's on the front with a circular hole. Similar to the key hole that's on bike locks.
Tubular key
A tubular key (sometimes referred to as a barrel key when describing a vintage or antique model) is one that is designed to open a tubular pin tumbler lock. It has a hollow, cylindrical shaft which is usually much shorter and has a larger diameter than most conventional keys. Antique or vintage-style barrel keys often closely resemble the more traditional skeleton key but are a more recent innovation in keymaking. In modern keys of this type, a number of grooves of varying length are built into the outer surface at the end of the shaft. These grooves are parallel to the shaft and allow the pins in the lock to slide to the end of the groove. A small tab on the outer surface of the shaft prevents the pins in the lock from pushing the key out and works with the hollow center to guide the key as it is turned.
The modern version of this type of key is harder to duplicate as it is less common and requires a different machine from regular keys. These keys are most often seen in home alarm systems, at least in the United States.
Security on these types of locks are problem, as rediscovered recently. It's known as the "Bic Pen Trick."
Edit: linky
They are fairly easy to pick. I had to open one when I misplaced my keys in our last move. Of course, about two hours after I got it open, I found the keys. 😉
