- Jan 4, 2001
- 8,253
- 14
- 81
I have a 2002 Pontiac Grand Prix GT (3.8L naturally aspirated engine).
When the engine is cold the engine will stall out unless I give it a bit of gas. Also at while driving at low RPMs it will start to stall. After the engine warms up then it runs fine.
I check the MAF sensor and it seems fine; I blew some canned air over the resistor but it doesn't look like there was a lot of build-up on it.
I took off the EGR valve and shot some CRC Throttle Body cleaner into the opening. There really isn't much in there for me to scrub, and it did not appear to have any physical buildup of junk in there. Also the little spring piston thing (not sure what it is called) seems to move relatively easily.
I took off the Idle Air Control valve and I think there could be a problem with this. When I first took off the IAC the little plunger looking guy shot off from the spring, which didn't seem normal. I sprayed some throttle body cleaner in and around that part (the plunger was covered in carbon). I screwed this plunger part back into the IAC valve body and it really doesn't move up or down. Should this part freely move up and down by my finger, or should it have a lot of resistance?
If anybody has any advice on something else I can check please let me know.
