- Mar 16, 2007
- 4
- 0
- 0
Hi everyone. My first post here.
I'm building a gaming PC using a CM Stacker 832 and I'm using a CM GeminII cooler.
What I'm looking for is the best configuration and choices to make regarding case (and heatsink fans).
Obviously I'm looking for the least noise possible while providing the best benefit. It would be a bonus if the fans had blue LEDs (the wife and I like them).
As you may (or may not know) The Stacker comes equipped with 2 fans, one (unlit) fitted to the back as an exhaust, one in front of the 4 in 3 HD module (lit). I also figure I'll get two high airflow (looking at the CM 120mm silent LED fans) for the cooler. It's the other ones I'm not sure about, the sidetray and the top blower.
Any advice would be appreciated.
