Stack Overflow error in Audio Catalyst
Booty
977
All the sudden every time I try to open audiocatalyst it gives me this "stack overflow" error. What the hell is this? I tried reinstalling once, and that solved the problem, but since then I have restarted and it's doing it again. Help?
The only recent change to my system was I installed IE 5.5, in an attempt to get rid of this weird GoHip plugin that I accidentally installed, which didn't work by the way. Anyone know how to get rid of that too?
Ponyboy25
462
Don't ask me what the hell "Stack Overflow" means, but I had this problem with Tie Fighter CD running under Windows 98. All I did was add a line to the config.sys of my system. I don't exaclty recall the line, but it was something like 'Stacks=9356'(no qoutes), or something like that.:confused:
bighurtx82
206
A lot of times a stock overflow means that the memory allocation for something has been exceeded. You probably need to find a way to increase the memory allocation but I have no clue where that could be found.
