not sure if theres a sticky for this so apologies in advance.
alright, so I'm running the e6400 ds3 combo.
i have it OC'ed to 3432 mhz there abouts, (429x8). I have adjusted the voltage the vdimm and the mch as I have OCZ2P8001G and it requires 2.1v as I understand it, so that's at +3 mch at +3 as well and my vcore is at 1.408 according to everest ultimate however I have it set to 1.437 in bios (i think) the one immediately above 1.425 it may be 1.432. and my ram timings are 5-4-5-15.
new heres the issue, every stability and stress test I give this thing it passes, except orthos.
I know others that have OCZ ram have experienced difficulties as well but I'm wondering if any of you have any insight into that?
my stability test passes:
dual 32m superpi with and w/o affinities.
dual prime 95 w affinities for 1 hour (then turned off because i was bored)
everest ultimate stess test
orthos gromacs (20 minutes then bored)
3dmark06
pcmark05
3dmark03
crystalmark
eh, there may be more that's just all I have ss'ed. oh and can someone link me to the superpi that your forum members use? mine measures in seconds not ms's.
oh yeah I'll provide any ss's if it will help you help me out.
thanks very much I appreciate any help you can offer me.
p.s.
Intel e6400 2.13ghz @ 3432mhz 1.437v (429x8/1:1)
ThermalTake BigTyphoon CPU cooler.
Gigabyte 965p-DS3 BIOS F6b
X1900gt @ 610/690
2x1gb OCZ DDR2-800 PC6400 PLATINUM (2.0 multiplier) (5-4-5-15)
2x400gb seagate barracuda 7200.9 (RAID 0)
(xp corp sp2)
3dmark06
pcmark05
3dmark03
crystalmark
p.s.
X1900gt @ 610/690
(xp corp sp2)
