- Oct 14, 2003
- 8,686
- 3,787
- 136
Toms has one of the only modern SSD battery life review: http://www.tomshardware.com/reviews/notebook-battery-life-storage,5152.html
Though the platform is not ideal, battery life comparisons are far superior to sticking in a power meter and inputting that number as a comparison.
The reviews show SATA-based SSDs are generally better in battery life than NVMe ones. The top HDDs can beat lots of the NVMe SSDs in battery life.
Important note in the article:
The very frugal HDDs have peak power in the range of 2W, while NVMe SSDs can reach 5W, or more. So as the article states, if the firmware is not done well, you may have a case where even with very low idle power, it realistically can't transition to idle and vice versa fast enough, rendering power management moot. The reviewers(and readers) mindset is also a problem, because they usually think in terms of Desktops. Desktops HDDs use 3-4x more power in load, while SSDs are viewed with little distinction between Desktop and Notebook usage.
SSD reviews need to add battery life as a comparison. Forget W numbers. Minutes and Hours is what should be tested.
The wake time is usually determined by the controller or the firmware. Some controller makers develop the firmware in house, but some SSD manufacturers choose to build custom firmware. Developing firmware is complicated and expensive. Not every company has the resources to dedicate to corner-case work, like making efficient wake time.
