Hi all
I have a new PC with Gygabyte h87m-d3h mobo. I use a Sandisk 128gb SSD to boot my windows 8 and keep certain programs. The PC was put together at a local computer store and worked perfectly well for about 3 weeks. Last night I was installing a game from Steam onto my second drive, a 1TB HDD. It was late so I went to sleep while leaving it on. My power options would put PC to sleep in 3 hours, which was sufficient time for the game to install.
Today when I tried to wake my pc, the monitor would not wake up. So I had to reboot my pc. However, my mobo stopped recognising my SSD and would not boot! I checked inside and everything was connected. Only after I disconnected the hdd and connected ssd to another sata, my PC took me to a screen where it offered me to restore my system.
I accepted, but for the last 30 mins the monitor has been stuck on the screen with Gygabyte sign on it. No options, no animations, just "Gygabyte". is this normal, or does it simply not recognise my SSD again? Should it force it to power off?
Thanks
Both the power and the reboot lights are lit on my case, BTW. CPU, GPU fans are working.
Thanks
