SSD performance difference between low and higher priced.
Caminetto
We have a Dell Vostro 3450 laptop and want to replace the hard drive with a SSD. I have been looking at the lower end of the SSD market thinking that is the way to go since the laptop is not used everyday.
However I am going to the trouble of replacing the HD in this bastard laptop that needs a complete disassembly to get to the HD. So, will there be much of a real world difference in ones priced at around $60 and those priced a little higher?
The fastest SATA SSD is maybe twice as fast as the slowest one overall, depending on the benchmark.
But they're all fast enough that you probably won't notice the difference.
Since this is going in a laptop, I'd take a good look at the power consumption numbers on the particular drive at the particular capacity you're looking for. For mobile that's just as important as absolute performance.
Fair. I still assume (probably incorrectly) that most laptop owners are using their laptops as thin'n'light desktop systems, on AC like 95% of the time.
Benchmarks are in large synthetic. Get one that fits what you need as far as size, pick a reputable brand, and be happy. Real world says most of the time you won't notice much, if any, of a difference. If you are a regular desktop user (no video editing, high end gaming, etc) then just about any drive will do you. Samsung, Intel, Corsair, and a few others are solid drives.
Doing a quick Google of the Dell Vostro 3450, it appears to be a Sandy Bridge era laptop with an HM67 chipset, which might only support SATA-2 (3 Gbps), and if so, none of the higher speed SSDs would see their potential. You'd be capped a roughly 250 Mbps sequential read/write speed.
Oops. I was confusing PCIe 2 with SATA-2. nevermind....
Thanks guys.
I’m going with the PNY CS1311. Great reviews at Amazon plus excellent power consumption numbers from the 4/15/16 Anandtech review.
You're not always wrong though.
FWIW, while there are a lot of SATA-2 laptops out there (which, you're correct, does bottleneck sequential speeds on SATA-3 SSDs) a lot of the benefit the end user comes from the random I/O performance boost, where SSDs beat HDDs by a couple orders of magnitude, even with "slow" SATA-2.
If the only benefit to SSDs was sequential performance, we'd all still be rocking RAID arrays.
Heh. I hate those types of laptops. I wonder what the designers were thinking. One of the most often replaced items in laptop and they make it a 1-2 hour job minimum. I have a 2010 Dell Inspirion with the same issue. I decided two years ago it wasn't worth the effort unless the HD started going south or actually died.
Every laptop I look at now, I have to see the tech manual or a video showing access to the drive being easy for replacement.
Yep. Although I pretty much have decided on the PNY CS1311, the extra $30 for a Samsung EVO still is on my mind as I don't ever want to go through complete breakdown again. (I replaced a failed HDD once already in this laptop and hated every minute).
I know well this issue about an old laptop with SATA2. I put a 500GB Crucial MX100 on an eight-year-old lappie. The benchmarks show the limitation to 300MB/s. That was my impetus to add 4GB of RAM = 8, run the 90-day trial version of PrimoCache, and decide that it was all more wonderful than the 500GB WD Blue lappie disk.
And now I see wpcoe's correction. Certainly, newer laptops would have SATA3 controllers. But there are a lot of older laptops still in the hands of original owners or sold on the refurb market.
