Hi! My workstation has an i7-5820K with a motherboard that provides an M.2 slot (PCI-E 3.0 x4). I'm a software developer and plan on having some virtual machines running (database server, deployment test servers, permanent VM for running windows applications etc).
I want my VMs to run as fast as possible, but at the same time, I do not want to pay more than necessary. Would a 950 PRO NVMe M.2 SSD be overkill in my situation resp. would I notice a difference to, e.g., a Sandisk x400 M.2 drive, which is way cheaper at the moment? Which SSD would you recommend?
Thanks!
Thanks!
