Windows caches most of the stuff into ram, so after while, it's not so bad to be using a spinner. It's shutting down / starting up seems to be the most annoying. The one I am using here is ST500DM002, works fine with 8 gigs of ram. Have a bnib Intel 240gb SSD but too lazy to install. With next OS reinstall, perhaps.Going back to an HDD after an SSD is a big step backwards.
Well, this is interesting. Both Amazon and B&H are selling the Sandisk Extreme Pro 480GB for $216 right now:
http://www.amazon.com/SanDisk-Extre...8&qid=1429314396&sr=8-1&keywords=sandisk+480g
http://www.bhphotovideo.com/c/produ..._sdssdxps_480g_g25_480gb_extreme_pro_ssd.html
It's not an all-time low but it's a pretty good price for a top-tier drive. Hmmm.....
Don't have a SATA port to spare. Freeing one up could be done but it would be a pain. Plus, I like having applications and the OS on the same drive - there always seems to be a program that still expects and requires to be installed on the same drive as the OS. I'd rather just keep everything together instead of splitting OS and applications. Also it's more convenient for imaging and cloning purposes.
You could get a Syba 4 Port SATA III RAID HyperDuo PCI-e 2.0 x4 Card SD-PEX40054 by Syba for $35 from amazon which adds the SSD and a hardive to create a JBOD system.. Where the space at the beginning of the partition is the SSD and the hard drive is at the end. The program itself moves files around the drives depending on usage and you can manually set it to do it as well. So it shows up as a single drive and basically set and forget and works well for the majority of cases. You could tweak it in case you want some large files on the hard disk or the SSD. This is basically like the Raid thing but instead of getting twice the speed, it only writes to one of the disks at a time so no speed increase other than depending on if the data is on the SSD or the Hard drive. Windows dynamic volume also seems to work like this but there is no option for you to specify which drive the data ends up on like in hyperduo.
